Нет услуг
9 Month Shelf Life |
Storage Temperature Range 50°F (10°C) to 86°F (30°C) and out of direct sunlight |
Item number | Item description |
LRR | LOW TEMP. ROPE RUBBER |
TRR | TREAD ROPE RUBBER |
1 Year Shelf Life |
849-870 | VUL-GUM |
AX50U |
RADIAL OTR UNCURED REPAIR UNITS |
AX60U | |
AX80U | |
AX100U | |
AX120U | |
AX140U | |
AX155U | |
CT45AU, CT45AH |
RADIAL OTR UNCURED AND HEAT CURE REPAIR UNITS |
CT46AH | |
CT50AH | |
CT52AH | |
CT55AU, CT55AH | |
CT56AH | |
CT62AH | |
CT65AU, CT65AH | |
CT72AH | |
CT75AU, CT75AH | |
CT85AU, CT85AH | |
TOR1U, TOR1H |
BIAS OTR UNCURED AND HEAT CURE REPAIR UNITS |
TOR2U, TOR2H | |
TOR3U, TOR3H | |
TOR4U, TOR4H | |
TOR5U, TOR5H | |
TOR6U, TOR6H | |
TOR7U, TOR7H | |
TOR8U, TOR8H | |
TOR9U, TOR9H | |
TOR10U, TOR10H | |
TOR11U, TOR11H | |
18 Month Shelf Life | Storage Temperature Range 40°F (4.4°C) to 90°F (32°C) |
739 | BUTYL LINER REPAIR SEALER |
2 Year Shelf Life |
603, 603R | BP CHEMICAL GRAY GUM AND THERMACURE REPAIR UNITS |
604, 604R | |
605, 605R | |
606, 606R | |
607, 607R | |
608, 608R | |
609, 609R | |
610, 610R | |
620, 620R | BPT CHEMICAL GRAY GUM AND THERMACURE REPAIR UNITS |
621, 621R | |
622, 622R | |
623, 623R | |
624, 624R | |
625, 625R | |
626, 626R | |
627, 627R | |
CT45A, CT45AR |
RADIAL OTR CHEMICAL GUM AND THERMACURE REPAIR UNITS |
CT46A, CT46AR | |
CT50A, CT50AR | |
CT52A, CT52AR | |
CT55A, CT55AR | |
CT56A, CT56AR | |
CT60A, CT60AR | |
CT62A, CT62AR | |
CT65A, CT65AR | |
CT72A, CT72AR | |
CT75A, CT75AR | |
CT85A, CT85AR | |
GH200, GH218 | CHEMICAL CUSHION GUM |
SK12R | THERMACURE SKIDDER REPAIR UNITS |
SK16R | |
SK20R | |
SK24R | |
TOR1, TOR1R |
BIAS OTR CHEMICAL GRAY GUM AND THERMACURE REPAIR UNITS |
TOR2, TOR2R | |
TOR3, TOR3R | |
TOR4, TOR4R | |
TOR5, TOR5R | |
TOR6, TOR6R | |
TOR7, TOR7R | |
TOR8, TOR8R | |
TOR9, TOR9R | |
TOR10, TOR10R | |
TOR11, TOR11R | |
2 Year Shelf Life | Storage Temperature Range 40°F (4.4°C) to 90°F (32°C) |
1082 | TEM VULC BLACK CEMENT |
738 | SECURITY COAT REPAIR SEALER |
760, 761 | CHEMICAL VULCANIZING FLUID |
775, 776 | HEAVY DUTY BLUE CEMENT |
858, 859 | CHEMICAL COMPOUND A&B SET |
3 Year Shelf Life |
182, 182AR | CT-42 Chemical Gray Gum & Thermacure Repair Units |
184, 184AR | CT-44 Chemical Gray Gum & Thermacure Repair Units |
196 | CT-80 Chemical Gray Gum Repair Unit |
197 | CT-82 Chemical Gray Gum Repair Unit |
198 | CT-84 Chemical Gray Gum Repair Unit |
199 | CT-86 Chemical Gray Gum Repair Unit |
5 Year Shelf Life |
Storage Temperature Range 40°F (4.4°C) to 90°F (32°C) and out of direct sunlight |
603C | BP CLOTH BACK REPAIR UNITS |
604C | |
605C | |
606C | |
607C | |
608C | |
609C | |
610C | |
620C | BPT CLOTH BACK REPAIR UNITS |
621C | |
622C | |
623C | |
624C | |
625C | |
626C | |
627C | |
704, 704A | RUB-O-MATIC RUBBER CLEANER |
AX50C |
RADIAL OTR CLOTH BACK REPAIR UNITS |
AX60C | |
AX80C | |
AX100C | |
AX120C | |
AX140C | |
AX155C | |
CT45AC |
CT46AC | |
CT50AC | |
CT52AC | |
CT55AC | |
CT56AC | |
CT60AC | |
CT62AC | |
CT65AC | |
CT72AC | |
CT75AC | |
CT85AC | |
TOR1C |
BIAS OTR CLOTH BACK REPAIR UNITS |
TOR2C | |
TOR3C | |
TOR4C | |
TOR5C | |
TOR6C | |
TOR7C | |
TOR8C | |
TOR9C | |
TOR10C | |
TOR11C |
